With the stock tensioner, wrap a cloth tape measure same as you would route the belt around the pulleys, subtract one inch from the untensioned length, and go to the parts store. If I recall correctly, the part number will be like K060747. K06 is a 6 rib belt and 0747 is a 74.7 inch long belt. Your length will be what you measured minus the one inch.
Mine is stock alt, waterpump, FFR pulley (no AC or Power steering) to crank - no Air pump (at least for now).
NAPA 060605 (6 rib - 60.5 inch belt.)
Hope this helps
