1 - 12 of 12 Posts
I'm ready to purchase an altenator. I'll be getting a one wire, chrome job, 100 amps or so. Do I get a GM or a Ford. I have an FE motor in my car and I'll be using the stock alt. brkts.
Thanks, Jeff
If you're going to use stock brackets, get the Ford. Your life will be much easier.
I bought a 1-wire GM alternator and Forte's brackets. It all bolted together just fine. I took the alternator pulley off of the donor alternator and bolted it straight to the GM alternator with no problems. It's a very easy conversion.
Don't want to steel you thread but I'm at the same point. I'll be using a March pully set up and would like to use a one-wire setup. Will the GM alt work with the March setup?
I must be dense, but I just don't understand the infatuation with 1 wire alts. I'm using a 3G from Mr Alternator with only two wires to hook up. Pretty simple if you ask me, and no hocus pocus to get it to charge.
Frank
I vote for the 3G-simple hook up and all Ford.
I have two applications-the roadster and a 93 LX Mustang convertible. I'm happy with them!
Best regards,
Chuck
I agree. I use an old style Ford part: Simple, cheap, light weight, low drag, easy to replace. So you have to wire an external regulator, big deal.
Functionality issues aside for the moment, I don't find the external fan setup very appealing either. Chroming them just seems to make them even more ugly.
Frank
Discussion Starter #12
Thanks for the thoughts, guys.
1 - 12 of 12 Posts
