I have a dash with factory cutouts and plan to use Autometer's classic gauge sets. The Tach and Speedo, are to large to fit in the pre-cut holes. If the holes are expanded to the larger stamped size, ithe dash holes will be to large to catch the entire gauge bezel. I don't plan on using a dash pad, just the vinyl covering, so dash hole size is be more critical. What is the secret to getting the right sized dash hole?
Official OLD GUY
Another Kevin,
Get a half-round file or a 1" drum sander for you drill and make the holes fit the gauge. I have the Finishline aluminum dash for my FFR and had to file too because my AutoMeter Classic Gauges didn't fit.
I'm running a 1/32" pad under my vinyl so had to fit and trim a few times to get it right. I wanted just a touch of pad so the gauges looked like they were set into the vinyl.
Doc
Doc,
I think a 1/2 round will take forever. I may go the 1" drum route though.
Also, I don't like the puffy dash look. Where did you get the thin pad from?
