1 - 20 of 30 Posts
Guys,
I'm to the place where I need to make a decision regarding turn signal solution. Time to show and tell me your turn signal switches, what has been working the best?
Chris.
El Conquestador
I'm using the Russ Thompson turn signal. He is a vendor, check out his link!
Russ Thomsons signal
If you don't like the Russ Thompson TS, American Autowire makes a toggle that will work the turn signal and the brake lamps without any black boxes or electronic gizmos.
Russ Thompson's turn signal...
Give Gordon Levy a call.
He has a very simple dash mounted turn signal switch. It is operated by a toggle switch and has a build in timer for shut off.
I've had mine 6 years now and I love it.
[ April 03, 2007, 03:40 PM: Message edited by: mikiec ]
Russ thompson, looks cleaner than the Tristates setup, and its a Volkswagon unit,so quality is'nt problem. you do have to send him your hub for machine work.
I have one of Richard Oben's from Northracecars.
Turn Signals, we don't need no stickin turn signals!!!
Having said that, I am using Painless Turn/4-way toggel switch set up.
Tim
I am using a toggle with built in LED mounted left of the steering wheel. The I^2 unit has self cancelling signals built in = cats meow!
Troy
just another builder
I plan on doing similar to rod, but with a simpler momentary switch to work with The I^2 unit w/ self cancelling...the same dash mount and arm sorta thing as above
I've got the AAW harness, and I went with a little gizmo called BackOff, which operates with two momentary switches. Push down the left (or right) switch for 1 second to turn blinkers on for 6 seconds, 2 seconds for 25, 4 for 75. Push down both switches for 1 second to turn on the flashers, press 'em both again to turn them off.
I have a removable steering wheel, and this was an easy way to get turn signals without a bunch of toggle switches.
separate switches left and right. this is a FUN car, gives me something to do.
the passenger is always happy to turn them off when i forget, which is becoming less and less often...
Hand Signals..
You oughta see my 4-way flashers! :eek:
Eddie - You need to re-order your guages in the order of importance..
Oil Pressure, Water Temp, Oil Temp, Fuel, Volts..
I know - where was I when you were figuring all that out? I'll crawl back under my rock now.. :D
Another vote for Russ Thompson. Great vendor. He added a momentary switch to the end of his custom stalk [doesn't look like a VW]. I use it for high beams and flash-to-pass. Wiring diagrams to hook this up are included.
Pete
1 - 20 of 30 Posts
