I have the whole kit from TRI-STATE. What bracket is needed for the brake lines? Post pics if you got them. Also should I use a proportion valve.
Thanks Mike
Not sure which bracket you're referring to. Flexible brake line from caliper to mounting block came with my donor IRS. Just ran hard lines up to the mounting block which I fastened to frame. I installed a prop. valve but can't really comment on brakes yet since I've only drove around the block in the gocart stage. I did the brake pedal arm mod. with standard IRS and Mustang calipers & rotors w/ a 1981 Mustang MC. Have a nice firm pedal with little travel but haven't tried locking them up to test them out though.
I used Mike MAck's (TriStates) pre-bent rear brake line, which includes the stainless steel flex lines for each caliper, the connecting hard line and a block to tie into with your hard line from the M/C. There're some pics of it on the Phoenix build site, if that's any help. Good luck!
