1 - 10 of 10 Posts
Does anyone know if there is enough room under the hood,to fit weber carbs on a 460 in a MK3 roadster?
Thanks Don, I'll try over there. Someone posted the same question about a year ago without any response.
Maybe I'll give Wayne at Very Cool Parts a call and see what he says.
Vendor
I do not know right now. I have done stack injection on them with short stacks and the 10° angle cut manifold. I think it would be close with the extra short stacks on the webers
section 8
I think blue thunder makes the manifolds you guys need with the cerb flanges mounted at 45 degrees .I think they have a website. Bob
Vendor
The Blue Thunder manifolds ar 8° on the 460 and I am a Blue Thunder dealer. I just got a 460 straight, a 460 manifold cut 8° and a 427 FE manifold in today.
Wayne,
Any for an FE TP yet????
Thanks Wayne, I'll be calling you when I get to the induction part of the build. Not sure if it will be webers or stack efi.
In the end, is the stack efi setup cheaper than the webers?
Super Moderator
No. Stack is more expensive.
If you are going webers, be sure to use a short duration cam and low pressure (no regulator) style fuel pump. Redline Webers recomend the Carter low pressure fuel pump.
A cam with long duration does not work well with Webers. Webers (48IDA) perform better with a high lift, short duration cam and higher (10.0+) compression. 48IDF's are better for engines with lower compression and mild cams.
1 - 10 of 10 Posts
