1 - 20 of 38 Posts
does anyone have the parts # for weather pack connectors for headlights/turn/brakes or should I just buy the kit from replicaparts.com?
and should I be looking for 3 pin, 4 pin, or both?
Tha k
[/QUO
Thanks Chewy
I was on that website I bought the under dash I did not see the weather packs. I think I will buy them.
Discussion Starter #3
and any crimpers anyone would recommend?
Discussion Starter #4
I get my Delphi connectors from theelectricaldepot.com. Decent prices and has lots of options when it comes to connectors.
Discussion Starter #7
thanks. from what i'm understanding, i'll need 2 4pin connectors for the headlights, and 6 3pin connectors for the turn/brake lights, correct?
Discussion Starter #8
ok. after pricing individual pieces from theelectricaldepot, replicaparts pack is actually cheaper.
EChewy
Did you see that when you click on the pack that it suggest that you get the tool with it.
Its $120 used. With the ability to return it for a $100 refund.
Jason
Eugene,
Not correct. You'll use a total of 8 three pin connectors for all.
Headlights:
---High
---Low
---Ground
Front marker lamps:
---Low element (parking lights)
---High element (turn signal)
---Ground
Rear upper lamps:
---Low element (tail lights)
---High element (brake lights)
---Ground
Rear lower lamps:
---Ground
Discussion Starter #13
Tool and weather pack kit.
but i'd still need to buy additional male/female terminals, as the kit only contains 1 3pin set of terminals.
i think that Mike Everson's package is still the most reasonable one at this time.
Discussion Starter #15
thanks everyone.
it seems like unless you're ordering in bulk, it's a better deal to order from Mike.
male/female housings are around $2 for a pair, terminals are $0.40 a piece, and seals are $0.25 a piece.
for 8 pairs of housings (3pin), 48 terminals, and 48 seals you're paying way more than the $30 mike charges.
I bought a whole kit from somewhere with a good tool. I used it for the build and for several other projects since. Remember, building your car is also a good excuse for increasing your tool inventory!
Discussion Starter #17
IWISS Weather Pack Crimp Tool for AWG 24-14 Crimping Delphi Weather Pack Terminals or Metri-Pack Connectors- Crimp Terminals and Seal In ONE Cycle with Locator & Removal Extraction Tool https://www.amazon.com/dp/B07GB698KV/ref=cm_sw_r_cp_apa_i_IcljEbP14Q6C8
Found this crimper. Much cheaper than the $100 Delphi one and also crimps wire and seal in one squeeze. Arriving tonight. Review to follow.
  • Like
Reactions: emac
Discussion Starter #19
Eugene,
Headlights:
---High
---Low
---Ground
Front marker lamps:
---Ground
Rear upper lamps:
---Ground
Rear lower lamps:
---Ground
Fyi Jeff, Mike sends 4 pin connectors meant to be used for the headlights. He says this prevents confusing the headlight and turn signal wires.
Looks very similar to the one I bought with an orientation attachment.
1 - 20 of 38 Posts
