Regardless of the DIY on your list, more often than not a set of ratcheting wrenches will make your life at least a little easier. They aren't an essential for a starter tool kit, but more of a way to expand your kit and improve on efficiency.
If you're in the market, we found this set of ratcheting wrenches from GearWrench for 67% off, priced at $100 even, including free shipping.
Shop the Gearwrench Deal Here
Read more about ratcheting wrenches: https://www.autoguide.com/products/set-ratcheting-wrenches-gearwrench-now-67-off
knuckle room
For what it's worth I wouldn't buy that set at any price.
They appear to be flat instead of having a bit of angle on the box end
In most cases that leaves you little to no knuckle room when you wrap
your hands around the wrench. Sure there are times where you have
the wrench out in the open instead of against a flat plane/part but why
get a set that only works in some situations. Decades of refinement have
resulted in MOST box ends having and angle to them just for that reason.
I like a bargain if it truly is one.
DB
DB.
These wrenches have their place, but you have to understand how they work. To rachet 'on' the wrench has to face one way, to rachet 'off' you have to flip it over. Thus you cannot have an angle to the wrench head. They don't have the common 'switch' to change the rachet direction.
I've got a set or two similar to these and they work fine for me.:yes:
George
Btdt
DB.
George
George
I have some of the gear wrenchs and I know how they work and
that was a good price for them if that's what you want.
They are well made and I like them but as I said limited in use.
The better design also has no toggle you flip them over too BUT
they have a hinge just inboard from the box end and you get any
offset you need. If you are just buying one set, the hinged design
is a lot more useful than the flat ones. YRMV
