I just hooked up my Autometer Classic water temp gauge. Before I fired up the engine, i turned the key and the needle went right to 150 degrees.
A friend of mine has the same gauges and his does the same thing.
Any one have an idea on how to get it to start somewhere lower?
I'm using the stock sending unit.
Russ
Just Pluggin Along
I am using the Autometer Sport Comp gauges. I replaced the stock sender with the one that came with the gauges. Reads bottom of the scale when I hooked it up for the first time the other day. Now let's hope that it goes up when I fire it up this weekend for the first time! Not sure if this helps, but changing the sender is worth a try.
I was pleased to see that my Ultra-Lites came with an electric oil pressure gauge and sender.
