Once again summit send me the incorrect parts. I have the 87-93 style water pump and timing cover and i was wondering if anybody knew the bolt lengths?
Just measure the total depth of each hole, and go to a store with a excellent bolt selection and get what you need. The results will look much cleaner, and be much cheaper than stock. I used socket head bolt from a industrial fastener store.
FFCobra Captain
You can also call www.totallystainless.com
They have engine bolt replacement kits and sell the ones you should need. I bought a whole engine kit for around $60...but you should be able to get just the pump bolts too. Just be careful not to overtorque stainless bolts.
You can get the water pump bolts from here as well...
www.windsorfox.com
But bring your own lube since your gonna be taken it up the........well you get the idea - $60 plus $20 shipping will get you 13 bolts - stainless steel 12 point.
I would check out the local j/y - these are hard bolts to get hold of.
If you're not using the studs on the ends of most of them, just put Grade 8, 5/16 bolts in there. Breeze has the long bolts with the studs if you want them.
