I found this fix in the archives. I am sure quite a few have taken the advice. What a great and strait forward repair. Thxs Wade.
What is the fix????
Lee
the door latches have a piece that is press-fit holding the mechanism together. The "wade mod" uses a short carriage bolt and nut to hold things together to prevent the latch mechanism from falling apart. Kleiner also recommends removal of one of the springs, but I can't recall which one at this moment.
  • Like
Reactions: hefbadr
5/16 carriage bolt with nyloc nut. Grind down the carriage bolt head to about 1/16+ to help sit flush on door. It is now solid and no rattling or flimsy feel. I left bith springs in and seems fine so far.
Thanks for the link Chewy...awesome...I did a bit of Rube Goldberg repair on mine by peening the retaining piece for a tighter interference fit...works so far, but doomed for failure...next time it fails I'll do the carriage bolt repair. I also purchased the Breeze "Bear Claw" latches...but way too much scary modification required. They are on the shelf. Anyone want?
Even better, use a 5/16" elevator bolt and you won't have to grind the head.
Kitchen utensil Office supplies Nickel Tool Household hardware
Remove the little one that's attached to the lever with hooks on both ends but leave the one that's behind the plunger.
