1 - 3 of 3 Posts
Hi everyone! Who wants to make me smarter tonight?? I want to cut out the supply line and return line off the fuel rails. On the return line there is what appears to be a rubber release valve,(I am guessing here). THERE MUST BE A REASON FOR IT. Is it needed?
On the fuel lines there is a fuel pressure test point. You can measure the pressure without breaking into or bleeding the system. This is on the line which connects to the fuel rail.
Is this what you are referring to? Your call if you want to keep this feature.
1 - 3 of 3 Posts
