1 - 2 of 2 Posts
1964 Shelby Cobra USRRC by Factory Five;
Mark IV Chassis
Black Powder Coated Panel Through out
Not more then 800 miles
Fresh 1968-Ford 289 cu. in.
Aviad 8.0-qt. Oil Pan
Mellings High Volume Oil Pump
M-6250-E303 Cam Grind Number with Comp Roller Lifters
MSD 6-AL Ignition
MSD Pro Billet Dist. (P/N 8579 Proper Steel Gear Installed)
3" x 14" K/N Air Filter
Earl's Perf. Temp-A-Cure Oil Cooler (81300a )
Tremac 5-spd. Trans
M7550-t302 Ford Performance Clutch
M-6375-b302 Ford Performance Flywheel
Moser 8.8 Differential Assembly with WaveTrac*
FFR Deluxe 3- Point Rear Suspension
Koni Shocks at 4-corners
USRRC Dash fitted with 2-5/8" Stewart Warner Gauges
Russ Thompson Turn Signal Switch
Vintage Pin Drive FIA Wheels mounted with Mickey Thompson Street Radials front 26 x 10.00 x 15 , rear 26 x 12.00 x 15
PBR Front Brake Calipers / Rear Calipers Emer. Brake Capable
Wilwood Pedal Assembly (P/N 340-11299) , Wilwood Remote M/C Kit
This is a quality build with documentation of same "no donor parts" . The car is registered as a 1965 and carries Antique plates in Fl . with a "Clean Florida Title" . Any requests for additional information will be honored within 24-hours usually less . Please Serious Inquires Only !
Asking $39,600.00
1 - 2 of 2 Posts
