I've had this kit sitting on my shelf for a while now but never wanted the car to have down time to install it. Well, when my battery died and with approaching cold weather, I knew it was time to get this done.
Once I finally got the steering shaft removed, I measured 6 times and cut it to remove 9" from the distal shaft. Next I had to get a few couplers welded on. An interesting few interactions with an older gentleman who may have inhaled a bit to much zinc and welding fumes in his day, and I had my two piece steering shaft back. While his conversational skills might have been lacking, he did a decent job on the welding.
I got the brackets mocked up, drilled, and painted, and installed on the motor.
I "fabricated" a quick and dirty mount for the control unit by modifying a bit of thick aluminum angle, and I mounted it to the F-panel. After several hours of getting the electrical hooked up, it's finally installed. Power and chassis ground go to the controller along with a few wires from an adjustment knob mounted in the cabin. The adjustment knob gets wired into a keyed 12V and chassis ground, and the motor plugs into the controller box. Overall, it's a simple, if time consuming install.
I'll tidy up wiring a bit more once it gets warmer. I just got the new battery installed, but I haven't fired things up to test function just yet, and it will be at least a week before I can take a drive with the cold and ice/snow coming in. Once I verify that things work correctly and get a few blocks in it, I'm going to take it in for a professional alignment all around.
Looking forward to warmer weather, easier parking lots, and more settled highway cruising.
