I have diet harness and using stock EFI setup. And Yes I can see that I should have done a better job labeling some of the donor parts I took off and put on the shelf.
Question 1: On the harnesses that go to the driver's footbox near the computer I have one 8 pin plug which is labeled EEC (it appears to only use 5 or 6 of the possible pins). What does the EEC module look like that this plugs fits into? I have a black plastic module with two connectors on it (one green and one grey) which are similar to this harnesses plug. If this is the EEC, what is supposed to plug into the other connector on it?
Question 2. The harness coming into the cockpit through the trans tunnel that comes from the trans and speedo has a 6? pin connector on it. Where and what does this plug into? The harness is about 4 feet long from where it enters the cockpit. I don't see anything on any of my harnesses or anything else that this fits????
Thanks.
[ November 07, 2002, 06:55 PM: Message edited by: Bill32 ]
Thanks.
