1 - 3 of 3 Posts
I’m using the stock wiring harness and stock turn signal. I hooked up everything like the manual said. But when I turn the key, the indicator light on the dash lights up and stays on. (I’m only using one dash light for both right and left). When I turn the blinkers either right or left, the front and rear work fine and the indicator light on the dash goes out.
· Administrator
OK, that's easy. The relay that FFR supplies is hot all the time on the middle plug, except when the signals are used, then it is a ground. So, hook one side of light to the middle reply and the other side to a positive. When you turn on the blinker, it will ground and turn the light on and off.
- Bill
1 - 3 of 3 Posts
