Status
Not open for further replies.
Does anyone know what the readings should be tuning one of these cars with a four gas
analizer. I've got the analizer but no sheet telling what it should read and what is rich or
lean. I guess that is what you get for getting a real good deal on a old machine. Any
help as what is what ????????????
Bob the deer hunter :confused:
It's pretty difficult to get a real firm idea of the air/fuel ratio with a gas analyzer - but it you can get a ballpark guess if you have enough experience with the machine.
Usually you would use a AFR meter for this, with a wideband O2 sensor to get a good reading. Shops that operate a chassis dyno will usually have one of these on hand that can be rented on the dyno.
I have a afr meter on the cobra but several of my friends want to be able to tune there cars and they don't want to install a O2 sensor on there cars so this machine was the answer if I can find some guide lines to follow.
Standard Afr meters are garbage to tune by.You need to use a heated wide band HEGO or UEGO (NTK) to accurately tune any vehicle. Gas analyser's especially tail pipe are way to slow and have poor resolution.
Phil
Also,
if their using the standard J pipes they have 02 sensor bungs in them. So, Im not sure how much $$ the gas analyser is but a good wide band made by autronics can be had for about $1500. You can use it to tune by and then plug the sensor hole. Have a few buddies go in on it together and share it not a full time requirement to use one by any means.
Phil
mk 1.5 original
you can set your idle mixture settings with that machine real easy. but loaded adjustments would require a dyno and still would not be as accurate as a wideband sensor the dyno shop probably already has. for no cat. and a mild camshaft I would expect to see no more than 1.5% - 1.8% co and hc below 500 ppm for idle readings with everything hot and operating temp.
Motorheadcrm, thank you that is what I really need to see is some numbers. that will go along way in telling what is what. My car is rich on idle and I know it so I couldn't go by my numbers to try and set up other cars.
Bob the deer hunter
Status
