my book says it comes preassembled but m ine did not. I have a C shaped bracket that backs up to the lock on the inside of the trunk. Does anyone have a pic of one assembled? Also, did you guys have to cut that square rod that engages the hook to clear the trunk aluminum?
dave
Cobra Nutcase
Mine wasn't assembled either. There should be two nuts/bolts to attach your latch mechanism to the c-shaped piece. The screws go through your handls & trunk and attach to the c shaped piece. There should be two small holes where these two screws should go into. I had to drill them out a little. Yes you have to cut the square arm off to clear the trunk floor, Hope this helps.
It does not come pre-assembled...It does not come with all the parts either....
I made my own mount system (as best I could figure), and it works fine.
The mounting holes are off center. I used 5/16 button head allen screws (stainless), and a combination of nylon stand-offs and lock nuts.
Drill the mounting holes in the trunk lid very accurately , using the lock mechanism as a guide.
Run the 5/16 bolts through the holes and back with washer...tighten with lock nuts....(on the inside). Slide a 1/2" long nylon spacer over the bolt . Attach the handle using the supplied counter-sunk machine screws , so that the handle will be parallel to the lip of the trunk lid , when the trunk is closed and locked. Now place the lock mechanism over the 5/16 screws and spacers , (being sure the the locking hook is down )..and tighten the 5/16 nuts onto the screws.
Hopefully , everything was lined up so that the hook will wrap the steel sleeve that goes through the body.
If you are confused , good , so am I. ;)
ok thanks guys, i just wanted to make sure before i cut that square rod and shot myself in the foot. I had all the fiberglass cut at FFR so lets hope its not off center..
Dave
