Gen 1 Coyote. Used to idle at ~ 1800 rpms for 7-10 secs before dropping to a normal 800. Does the same when stopped at a light. Have been working with a tune outfit to log rides and the flash corrective tunes. It has helped some, but it feels like the car wants to re-learn the high idle.
I've checked for vacuum leaks (with both propane and starter fluid); no leaks. Cleaned the MAF sensor.
I recall that with my MKII, the TPS voltage effected the idle. It's the last thing I know to do, so how do I go about this on the Coyote? What is the target voltage? Is there a Youtube video out there?
Any other thoughts?
Oh, Speed Dial is installed. After the last tune flash, I removed the Speed Dial fuse and took a ride; car idled good (though threatened to die a few time, but didn't). Only real issue was it backfired on exhaust brake a lot.
Any other thoughts?
