1 - 2 of 2 Posts
ED, MY QUESTION HAS TO DO WITH AN OPTION I READ ABOUT WHEN I BUILT MY FIRST COBRA DEALING WITH A TREMEC MID-SHIFT OPTION. IS THIS SOMETHING YOU HAVE TO FABRICATE OR IS IT AN INTERNAL MOD.THAT IS UNDER SOME KIND OF INSPECTION PLATE ON TOP OF THE TRANS. I HAVE NEVER SEEN ONE OF THESE AND HAVEN'T HEARD MUCH TALK ABUOT IT EITHER.IS IT POSSIBLE AND DOES IT REALLY WORK? I WOULD LIKE TO HAVE INFO ON THIS BECAUSE THE SOUND OF A SHORTY SHIFTER LOCATED CLOSER TO THE FRONT OF THE TRANS HUMP IS SOMETHING I'D LIKE.THANKS,BILLY
The Never-Ending Builder
Billy,
Contact Mike Forte, he's one the the vendors on this forum. The mid shift for the Tremec requires a special shifter for that position. It also requires that the shift rail for the rear most shifter position be removed and the shift forks in the mid position be set up to function with the new shifter. Mike sells the Tremec with all this already done with just the extra cost of the new shifter. Forte's Part Connection
1 - 2 of 2 Posts
