I put my motor in today and had a problems. The tko 600 does not line up with the rear end side to side. Is that normal?
What rear suspension do you have?
Yes. Make sure that the drive line is installed exactly parallel to the frame rails, and the rear diff is exactly perpendicular to the frame rails. The U-joints will do the rest.
Be sure to check pinion angle.
