Would like to know what the torque values are for the panhard bar bolts.
Also, when I raise the car (pick up the frame from the back) the axel tube hits the diagonal frame member. I thought the bilsteins and the three link didn't allow that. Will I have an issue once the car is sitting on rubber?
Thanks.
I have the same setup as you and the shock mount should be in the top hole on the frame. I have about a 1/4 in of clearance at full drop.
Discussion Starter #4
Tom and Dan,
I am in the top holes. If I lift up on the rear of the car, the rear end drops and hits the frame...
Torque value on panhard mounting bolts?
Thanks!
