Status
Not open for further replies.
1 - 10 of 10 Posts
· Senior Charter Member
I fitted my power brake booster last night so I had to enlarge the hole in the mount. I used a combination of a sawzall, drill, 3" air cutter, and a file to clean up the mess. I'm sure there's a "right" way to do this. So, what tool am I missing?
Similarly, what's a good tool for making cuts (particularly inside ones like for a heater) in the aluminum panels? Nibbler? Rotary cutter?
Thanks.
· FFCobra Fanatic
2 1/4" or 2 1/2" hole saw and a little bit of light oil. Much neater and cleaner
· FFCobra Fanatic
I used a rotary cutting wheel and my compressor last night to cut the hole for my heater. Took a while (I think I need the BIG compressor) and a nibbler would probably be better, but my lines were straight and it didn't scuff up the firewall.
· Charter Member
I just used a 2X4 with a piece of metal with a 1/4" hole to hold the center and held it to the back side with drywall screws. Use lots of oil or you will no longer own a sharp hole saw.
Hole saws are THE "I dont have a lot of tools, i.e. drill press" tool for this stuff
· Premium Member
I clamped a piece of 1/4" steel across the back side and used a hole saw like everybody else. However, in hindsight, I should have used this as an opportunity to convince Beth that I NEED a plasma cutter. :D
Discussion Starter · #10 ·
Originally posted by Jeff Hamilton:
I use a holesaw. C-clamp a 2x4 across the hole and redrill it.
Nice. Much better way to do it.
1 - 10 of 10 Posts
Status
