1 - 20 of 58 Posts
Guys,
Sorry if this is obvious but what tranny fluid do I use in my TKO 600? I used the search and didn't find the answer. I also looked in my garage for the manual last night but couldn't find it.
Garrick.
Royal Purple also makes a synchro-max fluid which is the full synthetic replacement to the GM syncomesh. I've been running that for yrs.
GM Syncromesh (so says the Tremec manual) - check Forte and Breeze prices before going to GM dealer. My local GM dealer was almost twice the price per quart.
Redline makes a GM synchromesh compatable product also.
Hi,
The GM# 12345349 is what Tremec recommends.
Administrator
Actually I have no idea but since the q's been answered so many times I thought I'd pile on just to irritate Wayne!!
:devil2::glare:
Hi,
You'll need 3 quarts.
Discussion Starter #16
Found the amount of fluid needed. Thanks Mumblerone for the PDF. I didn't see it the first time.
Thanks for the replies everyone. I think I should use GM Synchromesh!
You're all wrong!
It's GM Synchromesh!
Non-whiner
Wow, you mean I put GM crap in my Ford?
So should I use GM Syncromesh?
Ah - Yep - That's what I'd use...
Of course you could use Royal Purple's Synchro-Max oil as well..
I'd double check with a few others....
1 - 20 of 58 Posts
