I have a small timing issue. My engine is a rebuilt, mildly warmed over 302, slightly bored over. It was converted to a carb (Edelbrock 600) and has a mild cam (can't recall which one the builder said). I am not sure where the timing should be set. Any suggestions?
Jerry
Intitial should be around 12-14. Unless your running a vacum advance, then less. Total I wouldn't go over 34 degrees.
You want that 34 to come in by 3000 RPMs.
Barrow a dialable timing light to make it easier on yourself.
*edit, Geez I kan't spel.
[ July 16, 2007, 05:26 PM: Message edited by: mustangII460 ]
Frank...thanks for the input. What is a dialable timing light? I need to buy one anyway...would it be pretty expensive?
Jerry
