I figured I should check the timing since I
had the distributor out..
Even though the engine seems to idle perfect,
I can see the timing mark jumping back and
forth about 10 degrees or so.. The engine was
completly warmed up and I didn't notice any end play
on the dist shaft. The worm gear looks good...
Any ideas or comments would be appreciated.
Take the center bolt out of the balancer. Thenb grab it and shake it around. If there's any movement at all, take it off and inspect the key and key way.
Also look at the rubber in the harmonic balancer, they do fail after time
David W
Discussion Starter #5
Thanks for the info.. I'll have a look
at the harmonic balancer today.. What is the
spout?
it's the little square "plug" in the wire harness that goes to the distributor....maybe 1/2" x 3/4" rectangular gizmo. Pull it out to check base timing (that removes computer control of timing). Should be rock steady w/ the spout out.
like Richard said, that is normal with the spout in.
Discussion Starter #8
Thanks everyone! I pulled the plug and
everything look good now.. Eng is rock steady.
I think I got lucky since this is my first time
dealing with EFI..
