1 - 2 of 2 Posts
I have a bump steer kit with spherical rod ends bolted with nontaper bolts to the spindle.
When I bolt down this rod end to the spindle, where should all the rotation be? Should it be the rod end around the bolt or maybe use a star locking washer and seize the inner part of the rod end to the bolt making the bolt and the ineer rod end rotate together?
THRAMP-master
It shouldn't pivot on the bolt - the bolt and the inner, spherical part of the rod end remain "fixed", and the outer part of the rod end rotates around them.
Drive on!
1 - 2 of 2 Posts
