I have just finished installing a Kenne Bell blower on my 302. :D I did however notice that the stock throttle cable (supplied with the kit) seems to be a bit short. I routed it behind the engine towards the TB. It reached but has some serious tight bends in it so that the cable is a bit sticky to return to idle.
Does anyone have any routing suggestions, or maybe a Ford part number for a longer cable that will fit?
Otherwise this setup rocks
and I have a tough time to stay out of boost!!!!
Anyone with more info? I did not see any cables on Breeze's site.
I made a cable around the front side. A long sweeping bend. This helped out the sticky throttle.I had to make a few special parts.
E-mail Mark at breeze....I didn't know he makes a longer cable.....This might be the answer for you.
I had Todd drive my car while I stood on the side of the road.....That Kenne bell sounded real cool coming toward you...you could hear a slight whine from it.....Have fun!
I would also like to see a pic of that blower installed.
I used the lokar throttle cable. I think it was 40". It makes for a really smooth throttle. Mike Forte stocks it.
