1 - 3 of 3 Posts
I've seen several references to drilling a 1/8th inch hole in the top of the thermostat. What EXACTLY is the purpose and why don't manufacturer's put one in it??? Our car is running a bit hot and I thought I might try it. 351W w/ all Edelbrock components and a Holley 750.There may still be a small air bubble in the system. Thanx, Brian
Sometime there can be a "bubble" of air trapped by the thermostat that a 1/8" hole will pass. Some of the thermostats have a simple check valve already built in. My Autozone brand one did. In either case you still have to make sure the hole/check valve is at the top. All that said, the hole just makes it a bit easier to get all the air out and the water flowing initially through the system. Once you have a good volumn of flow and fluid I'm not sure it helps all that much.
It's just there to help til the t'stat opens.Most useful til the air is bled out of the system.Fairly useless after that.
1 - 3 of 3 Posts
