just another builder
for the holes in my head
...i have blue and high temp sealant both loctite brand....and 2) whats the best or easiest tool to use to install....i assume it's a through hole so no torque spec or do they bottom out?....okay that was 3
they will bottom out .use any silicone, screw em down tight end of story.i used a 5/8" long set screw from an old time hardware store. way less than the proud ford part#.
paul
Forte told me to put them in with anti-seize. This is a steel plug going into an aluminum head, so i guess this makes sense. The ones from Forte are threaded on the inside to take an alternator bolt. I used a short bolt to turn the plugs in with a rachet.
