I can't wait to here it come to life!!!Good morning gents. So today is the day I will be starting up my engine for the first time. I’ve got all fluids filled, with the exception of power steering, which will be filled before first crank. Couple of questions.
1. I’ve routed the lines so any high spots in the lines are below the top of the reservoir. Are there any concerns with the way I’ve routed the lines? I’ve made sure to zip tie the lines away from the steering shaft and pulley. When I finalize this, I’m either going to double up the zip ties or use the insulated clips.
2. Anything I need to consider bleeding the system? From what I’ve read, either filling the reservoir and turning lock to lock several times before crank will suffice and then just make sure to keep topping off the system during first crank or just filling the system and skipping the lock to lock procedure. Thoughts?
