1 - 12 of 12 Posts
FFR Craftsman
I picked up the package Thursday.
DAAAAAYYYYYUMMM they're gorgeous! I know what my weekend plans are now!
Funny, for those that have these, how many have this image of a Viking Goddess when you hold the pair of spats up???? :D
[ January 26, 2007, 10:41 AM: Message edited by: 289FIA_Cobra ]
Pictures, Herman, pictures! Give us some before and after action on installing these. Congrats!
Cheers, John
FFR Craftsman
John:
The journals been thin lately because I'm driving it more. But these along with the "still to do's" should fill in some of the void.
So here is my preliminary shots this morning:
Here, I lined up the very edge of the spats with the edge of the rear wheel well.
This is the gap left. Now a little bit will be taken up because the metal doesn't lay flat in this photo. When I get to the point for the final installation, using silicone around the edges per instructions, I'll need to push down as much of the metal as possible to ensure it's flat, and make the final drill holes.
The good news is that upon this prelimnary fitting, the doors do not interfere.
I'll have a few more shots this weekend.
How can I get ahold of Brian? I like those tons better than my FFR C/Fiber ones.
Me too. I would love to get a pair installed
before summer. They look great and would cover up some existing stone chips.Can you post Brian's contact info?
FFR Craftsman
Hi Herman,
Thank you for posting! They are going to look awesome on your car - love the "Viking goddess" analogy! :D I sent you a pm with some tips to get the fit better before you do any drilling. ;)
Mine fit great. Thanks again Brian.
Baron
"Senior"
Be careful as you only get one shot at drilling the holes. I started at the bottom and fastened it loose so it would be held in place before I drilled the top holes. Outer top hole next and again fastened looose. I think they look real good. On my MKI, I don't have that large of an inside gap.
FFR Craftsman
Discussion Starter · #10 ·
Thanks for that picture. Helps a bit. I see the gap is more aparent down low instead of high like mine but it looks a lot better. Like I told Brian, I'll have another go at alignment this Saturday and update this post.
FFR Craftsman
Discussion Starter · #11 ·
Update:
I spent the entire afternoon getting this done and I did as well as I could here. I have to say they look very good. I don't know if I did the best job compared to the two pictures above. I easily spent a hour per side "just" on the positioning part. Overall, I'm satisfied with the results. What I did find though, was the top edge just would not stay down. It would pucker up and as hard as I pushed it down flat and marked the holes, in the end, it just gapped up too much for my taste so I ended up adding one more bolt to the top. I couldn't find any pan-head bolts with a allen head design like Brian supplied so I simply used a finishing washer and 10-32x1" SS screw for both lower attachments.
Mine fit perfect!
1 - 12 of 12 Posts
