Home
Please take a look and feel free to leave comments.
Thanks.
Tim
Pro FFR Builder and Moderator
Looks good, are those my front brakes?
Discussion Starter #3
The fronts came from FFR. The rears are yours.
Tim
I thought so, they looked a little small to be mine. Nice job, please let me know if I can help.
Discussion Starter #5
They're 13" (actually 12.88") with 6 pots. Anything larger would not fit the wheels.
One question - I didn't get any instructions with the kit you sent. Were there supposed to be any? I think I have it pretty much figured out, but I don't have torque specs. Do you have those?
Thanks.
Tim
Torque on the rear hat bolts is like 17#. I go to that and then whatever is needed to be able to safety wire.
Please make sure that the hats seat all the way. Depending on what wheel studs you may need to drill out the stud holes in the hat to 9/16".
I have a high clearance front kit that uses a caliper that has 40% more brake pad area than the FFR/ Wilwood dynapro caliper. I designed the kit to clear the Halibrand replica wheels.
Nice build and website Tim!
Those brakes look great and should stop on a dime and leave 9 cents change!!
But you need to slow down, you're making some of us look bad. :001_tongue:
