Just got my Fortes de-gas tank and there is a threaded plug in the bottom of the tank. Should I seal the threads with teflon tape, pipe dope, or???
Ray
[ October 04, 2007, 12:03 AM: Message edited by: Ray ]
I use teflon paste.
Ray:
Shoot Mike an E-mail or call his cell number and ask him,he's the one to know.
Paul M.
Everything mentioned so far will work.
Newbie Dreamer
Should stay away from pastes, if a small glob should come loose it could fowl up a fuel pump, filter, strainer, sender... very easily and once it is in those it is virtuously impossible to remove.
Tool Collector
Grand Valley Dreamer, A De-Gas tank is part of the coolant system and not the fuel system.
Ray, What ever you use just don't use to much and you'll be fine, Frank
I agree, but if applied to threads very carefully, ensuring none is past the "lead" thread, and you carefully start engagement, you are probably better off than with tape. Just "stripe" 1/4 to 1/3 of the threaded section axially; no need to wipe the paste all the way around...that will just make a mess.
