What synthetic oil should I use for my T5 transmission.
thanks
What viscousity should I run?
Unless you are racing, Redline MTL is overkill... Put in a good grade of Dexron ATF or at the most, Mobil-1 ATF. Avoid any snake-oil concoctions made out of a quart of this a pint of that and etc... You get the picture..
I think I used a Valvoline synthetic ATF. I would suggest against the synthetic if your trans is older. The worn synchros will not works as well with the slippery synthetic, and you might run into to some problems shifting into third for example.
Ditto 331 Notch = Redline D4 atf
