I'm having some problems deciphering my transmission ID tag. I've got the shop manual but nothing seems to match up with what is in that. Here is what I have:
F0ZR-7003-AA REP-AV
13-52-199 70045 H3103
Is the car's serial number part of the vin suppose to be on the tag???
JC
1352-199 = Ford 1990 Mustang 5.0L V8 WC
source:
www.5speeds.com/t5
1352-199 90-91- 5.0
300 ft-lb rating (good)
Gears -> 3.35 1.99 1.33 1.1 0.68 - reverse ->3.15
source:
www.ddperformance.com
A cool thing about IDing Ford parts in general is that the year is the first part of the part code.
The first letter is the decade ...
"D" = 1970s
"E" = 1980s
"F" = 1990s (as in this case)
The number that is the second character is the year in that decade.
"D4" = 1974
"E8" = 1988
"F0" = 1990 (again, as seen above)
Knowing this can help a lot when cruising swap meets. Give you a rough idea what a part is. I almost bought a T5 that "was pulled from a wrecked '92 Mustang", until I saw that it was in fact, an "E8", and I want a World Class ('90 and later).
This works well for most parts made by Ford, but in some cases, it may signify when they started using a part, like a 1970 tail light in a 1972 car, etc.
"Knowing this can help a lot when cruising swap meets. Give you a rough idea what a part is. I almost bought a T5 that "was pulled from a wrecked '92 Mustang", until I saw that it was in fact, an "E8", and I want a World Class ('90 and later)."
The WC or World Class designation started in 1985.
Source: http://www.5speeds.com/t5/
