Status
Not open for further replies.
Hey all,
I'm in the early stages of the build, and I got the Street Performer seats with my kit. I've decided that I want to get the frame powdercoated, so I want to do all the frame mods before I take it to get coated. From what I've read, the seats are a really tight fit and the e-brake handle may need to be relocated. Can someone give me some details on the e-brake relocation? Most importantly, exactly where is the best place to relocate it with these seats? It would be great if I could do any welding I have to do without having to fit the body, doors, and the seats in the car.
I was looking at the Fiero e-brake setup in the FAQ. Will this work with the Street Performer seats?
Thanks a lot!
[ August 11, 2002, 07:57 PM: Message edited by: Cobra3657 ]
Out-of-control teenager
Although we have not done the fiero e brake, I believe that it is narrow enough that it mounts on the drivers side and clears the seat. Someone else will have to add more info.
I have the clubman seats which I believe are the same as the street performers. When I relocated the fiero e-brake to the drivers side I had some interference problems when I tried to mount it like what is shown in the FAQ area. I ended up mounting the handle to the top of the 3/4 sq. tubing instead of along side it. Others have said they did not have any clearance problems when mounting it along side the tube - Maybe it is how I mounted my seat that gave me the clearance issue.Either way I would still mock it up before I started drilling holes. I spent a fair amount of time looking at the best way to route the cables. I ended up buying some custom made cables that where just the right length.
Well, after looking at the FAQ again, it looks like the handle could be located anywhere along the 3/4" tube that it's mounted to in the picture. I don't mind drilling holes and filling them with bolts in the powdercoated frame, but if there was going to be welding involved, I wanted to go ahead and do it before the powder coat. Will I have to mount the body in order to mock up the seats? I've heard the clearance between the body and the seats is very tight.
Status
