Status
Not open for further replies.
1 - 13 of 13 Posts
· FFCobra Fanatic
there was a post re: this same subject just a few days ago. I use a yardstick, and a marker! Just too simple!.... :D
· FFCobra Craftsman
Rivit spacing tool from Aircraft Spruce, Alexander Air. Spaces and keeps straight lines.
I just used an old metal ruler, and drilled holes in it at the 3" and 2" mark. As for straight that depends on steady hands and a sharp bit!
Derrick
Tuba1973
· Senior Charter Member
I've always used a thin piece of aluminum about 18" long as a template with pre-drilled holes spaced at 1.5". I offset the holes so that they are closer to one edge than the other (~1/2") so it's easier to align along an edge. Once you hold/clamp it in place you can drill your first pilot hole and cleko it in place or use one of the FFR predrilled holes for proper alignment. The thin sheet metal template allows you to conform to curves/right angles as needed.
· Super Moderator
This is the spacer from AirCraft Spruce - well worth the $36. You don't want to drill through it - you use it as a layout tool. I did drill through the hole at one end, then I would Cleco it to the panel and stretch it out to get the proper rivet spacing and make my marks where to drill
P/N 12-11700 $36.250
You can get the drills, spacer template, Clecos, and Cleco pliers from AircraftSpruce. They have very good prices on all.
1 - 13 of 13 Posts
Status
