I have a Flaming River manual rack, 255/17 in the front with FFR LCA's. The rack had no stops in it, and it took a full 1 inch spacer to stop it from hitting the F panel. Does this seem odd?
Troy
That's exactly what I did.
Mine ended up at 1.30" with the FFR supplied UNISTEER manual rack. This is with the FFR lower control arms and 245/45ZR17 Nitto's on 17x9 Cobra R wheels.
where and how do you put these stops, thanks, chas
Mine was an inch too on one side 1/2 inch on other......CHIPSDAD......Under the rubber boots.Don
I have the same problem (and setup). Can you post a picture of how you did it?
I made sure my rack was centered, then set my outer tie-rods, so the rack stops are the same size on mine.
Here are the rack stops -
Here is where they go -
I made mine from a piece of plastic pipe from Lowes. Pipe needs to have an inner diameter of 1" and should be the heaviest wall you can get.
Hope that helps!
Thanks for the photos!
Finally starting!!!
+1 on the photos. Does every manual rack need some sort of spacer? I've got a manual 15:1 unisteer rack, but haven't started installing it yet.
