To install the bezel I'm talking about, I'll need to remove my steering wheel and upper column as a unit, then pull out Russ's turn signal assembly. I'll then slip the bezel over Russ's turn signal assembly, reinstall the turn signal, mount the bezel to the dash, then reinstall the steering wheel and upper steering column assembly. And hopefully the bezel will cover the hole in the dash that needed to be opened to fit the turn signal assembly.
Actually, my dash looks pretty good now, but a bezel is one of those little details that's pretty easy to do now since the body is off the car but will be just about impossible once the car's finished.
Jim Doak
FFR 2117
