From scouring this forum and other mustang forums it appears that the SROD bellhousing out of a 1979 - 1983 mustang will allow a tremec to bolt up to the SBF. The question I have is if there is a casting ID or some other means of identifying this specific bellhousing when I am at the local salvage yards. I am thinking that the tranny or engine may be gone and so I may be looking at just the bellhousing.
From these sources, I believe it may have the prefix "D9Z", but not sure.
I know I can get a new one, but being unemployed right now I am trying to save money wherever I can...:)
As always, thanks in advance to this great group of enthusiasts.
Chris
Hi Chris,
The SROD bellhousing and T-5 are the same casting number. They machine a different bolt pattern & larger ID for the T-5....
Discussion Starter #3
Is my best bet to try and make a template from my TR3550 trans then? (That way I can check the bellhousing in the yard) Is there any other method you recommend?
Thanks Mike.
Hi Chris,
The bolt holes are the key. Just measure the span between the bolts on the trans and look for the matching bellhousing...
Good Luck,
If you are looking at an old one it should be the D9ZC number you mention. They came in the SROD 4 speed Mustangs up to around 82-83 when they switched to the T5. You can tell from the top two holes being farther apart. Here are a couple pics to help you identify. I have one if you want a specific measurement to take with you...
TREMEC D9ZC 6394 BA
T-5 E9ZR6394 AA
