1 - 3 of 3 Posts
I got a bargain on a set of good looking Haneline gauges, maybe. The speedo and tach are only 3 1/2" in diameter with the outside diameter of trim at 3 3/4". Are these going to look bad? Or ist even going to be noticable?
Definitely a personal preference. I would cut circles of paper of all your guages and put them on your dash to be sure you will be happy with the look before you go through all that work.
I did several mock layouts on the aluminum dash with magic marker, and then hung the dash to see what it would look like while sitting in the car. When I wanted to try something else I just used acetone, erased it, and started over.
1 - 3 of 3 Posts
