1 - 12 of 12 Posts
PS... My 3.55's w/ OD (1995 stock tranny 5th gear) runs at 1900-2000rpms (motor kind of feels lugged down here). What speed am I doing...hahaha. Really, I don't have a speedo hooked up and this answer will give me an idea of how fast I am going until I progress forward with the build (too much fun driving). Approx is all I need.
Thx
Matt
near graduate!
I run 3.55's and from 1900 to 2000 rpm, I'm between 60 and 70 in 5th.
Thx 3V
3 Generations on a MkIII
If you give me the over drive ratio, and rear tire size, I will give you a very close speed.
What size wheels you have will make a difference. I have 17 inch wheels, 3.55 rear and a T5Z and in fifth I am cruising 75 at 2000 RPM
Matt,
315/35-17's are 25.75" dia. The T-5 has a .68 overdrive. With 3.55's, that gives you about 66 MPH at 2,000 RPM in 5th.
Kevin
I'm in the same boat as you. Got a cheap GPS.Gives speed to 1/10 of mph.More accurate than radar.
I'm running 275/40/17 with 3.55 gears. 5th is about 72 at 2000 rpm. Gps helped me dial in the correct speedo gear
Keven: "315/35-17's are 25.75" dia. The T-5 has a .68 overdrive. With 3.55's, that gives you about 66 MPH at 2,000 RPM in 5th"
Yep. In my computer sim, I get 63 MPH, that's counting the Drag Co at like ONE.
Jimgood, nice cal!
FFR Craftsman
I never looked "closely" but by the time it stops "lugging", its around 70mph at 2000RPM; I have T5WC with 3.55 rear, and 315/35-17 rear tires.
I have P 275-40-17 , 3.27 gears and a T5. We clocked it with a new car and I'm doing 2000 rpms and going 70 mph.Roger
1 - 12 of 12 Posts
