Craig - you'll get a bunch of different answers on this one. I run solid mounts on both the engine and trans. No problems in 21,000 miles, and I beat the crap out of it every time I take it out of the garage. Others say you MUST run a rubber trans mount if you run solid engine mounts.
The following text is from Moroso's website.....
"NOTE: Solid Transmission Mounts must be used in conjunction with Solid Motor Mounts to prevent breakage of engine block and transmission case due to torsional stress."
