It's time for me to let go of my Cobra. It looks like I'll be moving overseas next year. Lately I've been so busy that I don't have much time to work on it or drive it. It currently has 950 miles on it and needs body work and paint and some other finishing details.
MKIII Roadster F5R1004275RD. Delivered September 2004. Titled and registered in Virginia as a 1965.
FACTORY OPTIONS
Pin-drive width IRS
Full-width roll bar
Powder coated chassis
ENGINE
Ford 302, short block about 3 years old with about 16k miles
Ford high volume oil pump
Ford high volume water pump
Edelbrock Performer 5.0 aluminum heads
Edelbrock Performer 5.0 Upper & Lower Intake
X3Z computer with matching mass air sensor and 24# injectors
70mm throttle body
FRPP 1.6 roller rockers
E-303 cam
CSR radiator fill neck
New 3g alternator from PA Performance
3-core radiator
New MSD 6AL ignition box
Thermostat controlled cooling fan with manual override
New Energy Suspension motor mounts
DRIVELINE
T-5Z transmission with about 25k miles
New Energy Suspension transmission mount
Powder coated driveshaft from Denny’s Driveshaft
’99 Cobra aluminum center section with about 1,400 miles
3.27 gears
SUSPENSION
FFR tubular lower control arms, pin-drive width
New manual steering rack
Breeze aluminum offset steering rack bushings
Pin-drive width IRS
T-bird knuckles with T-bird brakes
Hubs drilled to 4.5” bolt circle by Stu Spencer
VPM polyurethane bushings
New rotors and remanufactured calipers
Power brakes with Wilwood remote fill master cylinder
INTERIOR
Classic Instruments electric gauges w/reverse speedo
Russ Thompson gas pedal
Ignited starter button
Battery disconnect switch
Lokar e-brake handle mounted on trans tunnel
FFMetal driver’s inner footbox wall
Ron Francis headlight switch
EXTERIOR
Black powder coated Quickjacks
Full-width roll bar
Black powder coated sidepipes
ELECTRICAL
Painless chassis harness
Optima battery mounted below trunk with FFMetal battery box
US Wheel, 84 series wheels
Front - Yokohama Avid S/T P235/60R15
Rear - Yokohama Avid S/T P295/50R15
$25,500
It's been sold!
[ September 24, 2005, 07:42 PM: Message edited by: Paul F ]
OT Moderator
Sorry to see you have to sell Paul. Seems like a good deal for someone.
Rob.
Discussion Starter #5
Dunlap,
Below is a list of what's left.
- Install radiator aluminum
- Intall front and rear wheel well aluminum
- Calibrate speedometer
- Mount doors and door latches
- Install interior carpet
- Install weather stripping and seal cockpit from wheel wells
- Install louvers
That's about it. I'm typing this as I think about it, so it is not a complete list. Basically, there's nothing left to purchase, just work to do.
I edited the original post, so it contains the new price.
Oops. I forgot about the wheels. They have no center caps, so you'll have to buy those if you want them. I was planning on eventually getting pin-drive wheels, so didn't bother to get the center caps with these wheels.
Paul
[ September 02, 2005, 06:44 PM: Message edited by: Paul F ]
Discussion Starter #9
As David said, it's as simple as unbolting the 15" wheels and bolting on the 17" ones. Just need to make sure the backspacing is correct for pin-drive width.
Paul
