Tim,
Listen to Billk, Captdon and Gordon.
Steel gear and loose the HD/HV/HP Pump.
TO BE SURE you have a steel gear....... My machine shop guy told me to do this.......
Take the old cast gear to your emory wheel. touch it to the grinding wheel (running of course) and watch the sparks. If its cast, there will be a small amount of dull red sparks. Now take your new steel gear to the grinder... Down on the collar where it make no difference, touch that gear to the grinder.... You should get a SHOWER of Brilliant sparks. THAT is HOW YOU KNOW if your gear is cast or steel. If you dont get that shower of brilliant sparks, YOU HAVE ANOTHER CAST ONE. And, they are hard to tell apart, even if you have one of both in your hands.
worked on mine, 15000 miles ago and I returned my HP or HV pump at these guys reccommendation.
SO FAR, SO GOOD,
BTW, the distributor I bought with the CAST GEAR, SHOULD HAVE HAD a steel gear. BUT DID NOT. I had to have the steel gear from my donor adapted to the Duraspark Distributor.
Change oil, filter and pump and ENJOY.
earl
[ September 29, 2002, 09:22 PM: Message edited by: CobraEarl ]
