2281 - 2300 of 2349 Posts
They'll tell you 20 gallons if you filled it to the top of the pump mount, but if you filled it to the top of the tank you can probably get closer to 25 gallons topped it off.
Connected & heat shrink wrapped dash wires up the wazoo. Almost done with it.
359269
  • Like
Reactions: jhargrove
1st RFM/FFR Legacy Winner
25,000 mile inspection. Jack stands under before I got under there.
359280
359281
359282
Drove it like I stole it! Took her out for a test drive after replacing the PS header gasket with Copper sealant, worked like a charm. now onto other items to fix! :)
Went to Mel's Diner for breakfast, and this beauty parked in front of me.
  • Like
Reactions: chrisarella
Can't praise it enough. Leaving it on for this heat wave, with the rear window rolled down. Really cuts down the direct heat from the sun and allows the air to flow through.
  • Like
Reactions: Toadster
Best day ever. 18 years ago November I took delivery of my roadster thinking my two young teenage boys and I would build it. After a few weekends in the garage they grew impatient when the car wasn't going together as quickly as they thought it would, so I shelved the car so I could participate with them in scouts, karate, youth group, mountain biking, etc, and I have absolutely no regrets. Life has taken many twists, all good, but hasn't left a whole lot of time for the car.
Now the best day ever part. My oldest son who is married and has 2 little girls wants to come over one weekend morning a week to help me finish the car. He needs a break from all the estrogen and needs some man time. Sunday was the 1st day and I am now reliving my original dream of 18 years ago. Lots of time with my oldest son, and the roadster is progressing. Best day(s) ever.
What a great Father's Day gift, Steven.
  • Like
Reactions: Steven K
Trial fit for new dash & installed the trunk lid struts.
359305
359304
Struts hold lid OK @ 28lbs each but think 35lbs would be better.
Threw it on the lift, used the trolly jack to lift the rear, and removed the rear passenger tire. I was doing a pre-drive walk around and noticed the right rear was low. Looked and sure enough, there was a screw in the tread. Dropped the wheel off to get the tire patched just now.
Adjusted the hydraulic clutch and now it shifts sooo much better.
2007 Calendar Cover Car
Finally got my superbrightled LEDs installed, and the new flashers. Had to rewire the hazards wiring in the fuse box, now the flasher installs from the back. It was too large to fit in the stock circular hole. Lights look nice!
Added a double din head unit which supports mirror link, android-play, apple car play, Bluetooth, MP5, most video and music formats, steering wheel controls and FM radio.. $44 to my door from China thanks to Aliexpress.
Yes - I am watching Ford vs Ferrari ;-)
359348
  • Like
Reactions: SC210Ford
Too Cheap to paint!
Had to fabricate a new front fender top vent, as the last one flew off while at speed on the track!
Finished wire prep for console stuff, transcover USB ports & installed a new Satellite antenna for GSP instruments. Moved bailout fire extinguisher to rear bulkhead from old position on the trans tunnel cover.
359349
359350
Grandson lent me his Bunny to help out with the work.:)
Next is install oilpan then the new clutch. Once the clutch & transmission are in will go back & finish the interior.
Tried out the car on the trailer behind my wife’s Ford Flex.
EcoBoost AWD so it’s got the power and 5000lb towing capacity, I’ve just never tried towing anything with her car. Now I know I can.
Pulled both cars out for a warm up so I can do their yearly oil change.
359362
Added a carb spacer, screwed up the carb settings, now i have to re-tune the carb from scratch.
  • Like
Reactions: Toadster
