· FFCobra Fanatic
Need to know the rotor diameter, and thickness if possible.
I tried to ask this over on the corral.net, but it was down for maintenance.
Jef E.
· Charter Member
I measured my SN95's and they are 10.5625" in diameter and .50 thick.
· FFCobra Fanatic
Richard,
Thanks for the reply.
I am a bit anal/perfectionist, and I want to have matching cross drilled and slotted rotors front and rear. There are virtually no aftermarket options for the t-bird irs rear disks. I have found several sources for the sn95 rotors. If I run into trouble, I may have to go with your set-up.
See Ya
Jeff E.
· Premium Member
Get the Cobra rears as they are available and do the conversion. The standard SN95 rotor is not really a good option. I have sources for rotors if you want the bird ones cross drilled look at my website at FFR1859 and you will see cross drilled Super coupe rotors. Cheers Richard.
