Go to epowersteering.com. They have a Factory Five MkIV specific kit for $650. Plan on doing it this winter. Contact epowersteering.com for details and instructions.ooh - specs on electric steering?
two oil gauges?My favorites are the Russ Thompson turn signal kit and my competition dash.
These are the items I see every time I drive it.
A secondary benefit of the high back seats is reduced buffeting from behind, makes the car a more enjoyable driver.High-back seats! Took the worry out of getting whiplash. Much more support, especially compared to the standard seats.
The competition dash is more than just for looks, in the standard layout, the steering wheel will partially block your view of the tach or speedo depending on which you put over there.Really like the competition dash look! I would second the Russ Thompson turn signal and power steering as a toss up for me.
Rick,I have made many changes to the car as I built it, not too much after. I believe that I'd have to say my best "change" was cruise control, that takes a lot of worry out of highway cruising, I also like my home made 5-link rear suspension. Full length deep well foot boxes on both sides come in a close second (or third if the case is such).
Regards, Rick.
Nice Dash!My favorites are the Russ Thompson turn signal kit and my competition dash.
408 kit instead of a stock rebuild, not really that much more money. Kept the same smallish carb so it's quite tame. Second would be rod end RCAs and QA1's greatly improved the ride on a 3-link (Mark sells a package). Scott
I did some experimenting, and the best balance was 15% window tint.NiceGuyEddie, what did you use to tint your mirror?
Bob,I made a lot of mods over the years. One of the best was a roll control. I used it all the time. Made it real easy to get started on a hill. Living in the mountains, that's kinda important. And it was fun for big smoky burn outs, too.![]()
Another good one was replacing the front lower control arm bushings with rod ends. It did not increase harshness, noise, or vibration like I thought it would. But it allowed the suspension to work as planned, instead of transferring wheel movement to the rest of the chassis. A noticeably smoother ride with rod ends.
No, I actually cut off the bushings, and welded in rod ends. A slightly different way to get the same results. If that spherical bearing kit had been available, I would done that.Bob,
Do you mean the spherical bearing inserts (or something similar)
Roadster - Chassis & Suspension - Page 2 - Factory Five Parts Catalog
#16332 - SPHERICAL BEARING INSERTS FOR FRONT LOWER AND 2015 IRS CONTROL ARMS
or something else?
