1 - 20 of 22 Posts
So, should I be greasing up my driveshaft yoke before putting it in the tranny? What kind of lube? Normal Synthetic bearing grease? Tranny fluid?
Anything special need to be done to the seal itself ?
I'm new to all this.
[ August 31, 2007, 12:22 AM: Message edited by: STI_Boy ]
Lube the yoke with Tranny fluid, the seal too
I second the tranny fluid.
What did SHE tell you to do? LoL !!
WHOA!!! Nice Topic.
Yes you should. You may be able to push it in without greasing, but your opportunities to push it in again in the future will definately dwindle.
if you don't grease it, you might bend a rod. It is more maintenance to fix a bent rod then to take preemptive measures.
You might want to protect it first before putting it in. You don't know what the shaft could of picked up while it was laying around not getting used.
Discussion Starter · #13 ·
I just wanted to let everyone know I greased it up earlier and it slipped right in as everyone said it would
Michael- it had been capped for quite some time so I was pretty sure it was safe.
Discussion Starter · #15 ·
I must say it felt great to *finally* get that tranny filled up.
On a related note, I did have difficulties measuring my driveshaft angle. Any tips ?
a little ATF. tranny in neutral, twist a little to get it in.
STI_BOY
You should know better than to ask such a loaded question :D
Discussion Starter · #20 ·
Originally posted by SR71:
STI: That's fine up front but how did you manage the the rear end???
That's the problem - I need some help or suggestions to properly manage the rear end.
1 - 20 of 22 Posts
